TwinTurbo.NET: Nissan 300ZX forum - Re: Temp Gauge Tweaking
Subject Re: Temp Gauge Tweaking
Posted by njz on September 07, 2011 at 6:08 PM
  This message has been viewed 109 times.
In Reply To Temp Gauge Tweaking posted by blackomega on September 07, 2011 at 09:44 AM
Message To test the gauge get a 3.5 watt bulb (194 wedge ) remove the temp sensor plug connect one end of the bulb wire to the sensor plug and the other bulb wire to ground, now turn key to the run position and the gauge should rise to hot. If it drops or does not go to hot you have a bad gauge. If it checks ok then change your sensor
