TwinTurbo.NET: Nissan 300ZX forum - There are stock boost jets
Subject There are stock boost jets
Posted by Stadsport (PHX) on September 05, 2011 at 4:41 PM
  This message has been viewed 87 times.
In Reply To No boost jets on a stock setup. If you get the ecu posted by zellamay on September 05, 2011 at 08:30 AM
Message I've pulled them out of many original wastegate vacuum lines. Under normal circumstances, the car will boost to 9.5psi. Run these lines straight to the wastegates and you get ~7psi. Take out the stock boost jets and you get around 4psi.
