TwinTurbo.NET: Nissan 300ZX forum - Can I just run without the A/C belt? I really don't need A/C
Subject Can I just run without the A/C belt? I really don't need A/C
Posted by Havoc300 (Chicago) on September 04, 2011 at 5:12 PM
  This message has been viewed 130 times.
In Reply To Find another Z32, measure, compare. (n/m) posted by zellamay on September 04, 2011 at 12:24 AM
Message I've checked and rechecked, and all belts and pulleys are on correctly. The only "weird alignment" is the water pump pulley and A/C belt. There is that spacer/washer that goes between the crank pulley and engine block but it does not give me enough clearance away from the block to keep the belt from rubbing on the water pump pulley. Tightening the A/C belt only moves it further up on the water pump pulley. I can't figure out why this alignment is off. So, in the meantime can I run without the A/C belt?
