TwinTurbo.NET: Nissan 300ZX forum - SCE Copper Head Gasket
Subject SCE Copper Head Gasket
Posted by diamond20601 on September 04, 2011 at 3:06 PM
  This message has been viewed 111 times.
Message I posted this on the general side but would like to know what people results have been of using these copper head gaskets? As I stated in a previous post I was going to be going with Eagle Rod with Wiesco Piston in the rebuild of the TT. All bearing will be replace with a water passage bore.
Normal thing that are done during a engine rebuild like freeze plugs and all the other normal things (ie timing belt, timing tensioner, water pump, turbos, and etc.)
I will not be doing anything to the heads at this point which I still have to finish planning out! I have been contemplating porting and polishing heads and other engine part but I have only had done porting on my previous N/A. It turned out well with no problems down the road but haven't had any experience on the VG30DETT port and polish.
Trying to get a spare block from the local guy but will see how that goes.
