TwinTurbo.NET: Nissan 300ZX forum - Again, can't give an opinion without inspecting it.
Subject Again, can't give an opinion without inspecting it.
Posted by zellamay on September 03, 2011 at 9:36 AM
  This message has been viewed 79 times.
In Reply To Re: I assume you mean that you will be in there anyway posted by EpiDeMiCc on September 02, 2011 at 10:58 PM
Message If you are not having symptoms of a bad clutch, I say don't take it apart until you are fixing tranny, which should be soon, imo. I think if the disc is worn enough to replace it, then a full clutch job should be done. If the disc is okay, then I think just removing the glazing would be okay. ... PS: if you erase the header line before responding, we don't have to read the same line twice.
