TwinTurbo.NET: Nissan 300ZX forum - Re: Pin 36
Subject Re: Pin 36
Posted by TRdave on August 29, 2011 at 4:52 PM
  This message has been viewed 105 times.
In Reply To Pin 36 posted by Draker (Eugene, OR) on August 29, 2011 at 01:24 PM
Message The connector to the sensor was questionable so i tightened it up. I tested the resistance of the sensor and i got 2.3 when cool. That should be good. I also made sure the wire back to the ecu was not broken and it is good. Now I just wait for the CAS to arrive right? Or do i need to push some new fuel through the rail or anything like that?
:[ http://www.twinturbo.net/nissan/300zx/forums/main/view/1104179/Yet-another-ECU-connector-pin-out.html ]
:Unplug the sensor, unplug the ECU harness. Using a meter check for continuity from the harness to pin 36.
