TwinTurbo.NET: Nissan 300ZX forum - Up and running then stalled again.
Subject Up and running then stalled again.
Posted by TRdave on August 29, 2011 at 9:20 AM
  This message has been viewed 114 times.
Message I was able to get my 91 NA up and running again this weekend after replacing the spark plugs with the recommended plugs and also a bad injector. It was running smooth for about 5 minutes then started smoking a bit heavy from the drivers side exhaust after the car was warm. A little later it stalled out and I checked the ECU and got two error codes. .
CAS failure and also fuel temp sensor.
The engine was very hot and my coolant level is fine. I am getting a new CAS, I really wasn't too confident in the one I had anyhow. What else would cause the fuel temp to be so high? Something with timing? Any suggestions?
