TwinTurbo.NET: Nissan 300ZX forum - Considering you pulled the engine, I'd do a boost leak
Subject Considering you pulled the engine, I'd do a boost leak
Posted by Audioquest on August 28, 2011 at 6:38 PM
  This message has been viewed 118 times.
In Reply To 92 TT 300zx Low End Slowness posted by blckdrgn on August 27, 2011 at 12:06 AM
Message test to make sure there aren't any leaks as well as double check all hoses are correctly hooked up. If there is a fuel smell you should check all the 16 or so fuel clamps to make sure, if for no other reason than to prevent a fire. I'd also test all the electrical components in the EF&EC section including the injectors.
PS -did you run ECU diag?
