TwinTurbo.NET: Nissan 300ZX forum - Help Twin Pop upgrade
Subject Help Twin Pop upgrade
Posted by c300zxtt on August 27, 2011 at 10:01 AM
  This message has been viewed 162 times.
Message He guys need a little help here. I have installed the JWT twin pop kit into my car with the exception on the ECU due to my Nissan Tech stating it was not needed since I have the AFC controller. Anyway I installed to exact specs per the instructions and the car now hardly runs and even messing with the AFC I cannot correct it.
So I figured I would return the car to the single pop charger set up untill I could send out for the upgraded chip. I plugged the new lines to the valve and next to the intake and took out the restricter but the car still will not run, idle and is puffing major smoke just like it did with the dual set up.
Any help on this would be greatly appreciated as the so called Nissan expert that told me to do it this was is of little help..... Thanks Guys
