TwinTurbo.NET: Nissan 300ZX forum - Fan destruction -- that issue happened because the
Subject Fan destruction -- that issue happened because the
Posted by jzack on August 27, 2011 at 12:02 AM
In Reply To lotta problems..guys i need help!!!!! posted by confusedalien22 on August 26, 2011 at 09:43 PM
Message plastic fan blades/body cracked over time. Eventually the fast spinning while engine is running caused a fatal fatigue of the parts. There are posts here from time to time about it happening to others...
Bad PCVs are one known cause of the dipstick issue you mentioned. Try changing them and see what happens? Also probably a good idea to replace the PCV hoses too. If engine is good otherwise (ie., good compression, no smoking, etc) -- no reason to replace it...
Good luck...
