TwinTurbo.NET: Nissan 300ZX forum - Having trouble setting base timing
Subject Having trouble setting base timing
Posted by VoslickZ on August 26, 2011 at 11:00 AM
  This message has been viewed 147 times.
Message I'm pretty sure I have everything hooked up right. The positive and negative leads are hooked up to the battery, and the clip is clipped the wires going to the coil pack on cylinder #1. Cylinder #1 is firing. Yet whenever I push the button for the strobe I don't see anything. The neighbor I borrowed the timing light from said he used it two days ago no problem. Is there anything that I'm doing wrong or is possible something is malfunctioning and not sending the timing light the signal? I'm trying to get it running so I can finish breaking it in before I leave, so thanks in advance.
