TwinTurbo.NET: Nissan 300ZX forum - Re: Update on boost issue
Subject Re: Update on boost issue
Posted by AsaHerring on August 25, 2011 at 11:02 PM
  This message has been viewed 82 times.
In Reply To Update on boost issue posted by tomas1329 on August 22, 2011 at 05:56 PM
Message Your problem is not the wastegates. The stock wastegates also have an automatic holding pressure of 5psi. Haven't read your previous post, but I believe you're ECU is putting the car in safety boost mode which wont let the car boost above 4-6psi. I currently have the same problem, but I believe my ECU or wiring harness has gone bad because I have done everything possible to fix it. Let me know if you figure anything out.
