TwinTurbo.NET: Nissan 300ZX forum - Re: It is still a mystery to me why auto R12 a/c systems
Subject Re: It is still a mystery to me why auto R12 a/c systems
Posted by aliaZ on August 25, 2011 at 10:38 AM
  This message has been viewed 109 times.
In Reply To It is still a mystery to me why auto R12 a/c systems posted by JMartz on August 25, 2011 at 07:44 AM
Message :would use the TSV and manual a/c systems the TCA as an additional system to control evaporator temperature. I though (till now) the only difference between manual and auto systems was the myriad of doors, door motors, inside, outside and duct sensors and an additional computer to control them.
:You mentioned wanting to add a TCA to your system in order to prevent evap freeze-up but do you have the right ECU to receive the signal?
I was going to use the output of the TCA to open a relay to interrupt the signal from the ECU to the clutch coil relay. Ideally I'd find a way to recalibrate the TSV for R134a, but that might be more trouble than what its worth.
