TwinTurbo.NET: Nissan 300ZX forum - TT vs NA oil pump
Subject TT vs NA oil pump
Posted by DaZedMan on August 24, 2011 at 6:37 PM
  This message has been viewed 1309 times.
In Reply To you sure? posted by BlackholeZ on August 24, 2011 at 05:36 PM
Message Got this from the Z1 blurb on NA>>TT conversions:
Oil pumps are different. They mount the same and are the same internally (on earlier
models) except for the spring for the pressure valve in the TT one is tighter so it produces more
needed pressure to circulate oil to the turbos and cooler. You can actually just change the spring to
the tighter one.
The 94+ NA oil pumps and the replacement NA oil pumps from Nissan are different internally to
the older ones and the TTs. They have internal gears with larger rounded teeth.
