TwinTurbo.NET: Nissan 300ZX forum - Re: When do you need to use a thicker-than-stock head gasket?
Subject Re: When do you need to use a thicker-than-stock head gasket?
Posted by jaidieray on August 24, 2011 at 7:07 PM
  This message has been viewed 147 times.
In Reply To When do you need to use a thicker-than-stock head gasket? posted by DaZedMan on August 24, 2011 at 06:46 PM
Message According to the fsm you can skim a total of .008thou off of the motor. If they skimmed .005 off of the heads then you still have .003 they could of removed if they had to (assuming your motor hasnt been skimmed prior). When rebuilding my motor the heads had to be skimmed .004 but not the block. The aluminum heads wear/distort easier than the block. You should be fine.
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=em&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=52&design=default&total=70 ]
90na2tt swap KH2 charcoal 5spd
93tt 5spd AH3=sold 90na auto EJO=sold
06 spec v=sold 95 awd talon=sold
