TwinTurbo.NET: Nissan 300ZX forum - I would pull the ECU connector
Subject I would pull the ECU connector
Posted by Draker (Eugene, OR) on August 22, 2011 at 6:38 PM
  This message has been viewed 123 times.
In Reply To What'd be the best way to do that? posted by idslave on August 22, 2011 at 01:56 PM
Message Use the ohm setting on your meter and put one end on the knock harness and the other end on pin 23 of the ECU connector. You should have some continuity there.
Make sure when you connect the meter you jounce the wires a bit to see if there are any connectivity issues.
