TwinTurbo.NET: Nissan 300ZX forum - maybe you can try removing the temp sensor from
Subject maybe you can try removing the temp sensor from
Posted by aliaZ on August 21, 2011 at 5:00 PM
  This message has been viewed 165 times.
In Reply To After adding a 12 oz. can the center panel discharge posted by JMartz on August 21, 2011 at 12:31 PM
Message the evaporator. It may be reading too low, causing the evaporator to cycle prematurely.
A side effect of doing this is your evaporator can freeze over.
