TwinTurbo.NET: Nissan 300ZX forum - Can injectors stay open?
Subject Can injectors stay open?
Posted by Michaels90na+1 on August 21, 2011 at 3:04 PM
  This message has been viewed 146 times.
Message So ive been fighting with leaking in jectors for a while now, pulling the plenum 4 times now. I had bought seals from z1 and they leaked no matter whatso bought directly from dealer so to know they would be factory. I installed them and tested with guage outside of car and it held good pressure for several days. Ok so yesterday i get everything put back and start it up and it runs perfectly no smoking and great idle. I shut it off to clean up and then 15 min later i start it back up and it would barely start and I did a power balance and it was only running on 4 cyl. I start it again and this time so much fuel leaked out it filled several cyl causing hydrolock. RIght now i took the plugs out to let the fuel evap. Now i did everything correct I know this time around and in testing before install they didn t leak at all. Could they be stuck open? Another thing is they seem to be very loud, more than they should be at idle. Help would be appreciated, thank you.
Click to View more pics
