TwinTurbo.NET: Nissan 300ZX forum - Re: setting throttle stops on z1 58mm cnc TB's
Subject Re: setting throttle stops on z1 58mm cnc TB's
Posted by brian913 on August 21, 2011 at 6:05 AM
  This message has been viewed 163 times.
In Reply To setting throttle stops on z1 58mm cnc TB's posted by WazTTed on August 20, 2011 at 06:35 AM
Message I had the same problem with the plates sticking. The book doesn't give a real setting, but just tells you how to make sure they are equally open with the dial gauge, and I suspect they are set at the factory as the screws have a dab of sealer on them. I found that having them just open enough not to stick, and then doing the setting by the book worked for me. The balance tube and the idle air control valve should do the rest to give the proper amount of air.
