TwinTurbo.NET: Nissan 300ZX forum - Check to be certain the belts are centered their
Subject Check to be certain the belts are centered their
Posted by Gordo 93TT Daytona on August 20, 2011 at 11:47 AM
  This message has been viewed 128 times.
In Reply To Accessory Belt Adjustemts..... posted by Havoc300 (Chicago) on August 20, 2011 at 09:38 AM
Message respective pulleys. It sounds like a belt is one 'rib' off center. AFAIK no belt should be near the edge of another drive system's pulley. Not even close.
Squeaking is almost always caused by either a worn belt (unlikely if you just replaced w/60k work), or a belt with too little tension. Lack of tension allows the belt to slip until it heats up and grabs the pulley surface.
You state you have 'good' deflection. Is this your opinion, or have you measured it? The FSM is very specific on where and how to set the belt tension for each belt.
_________________________________________________
