TwinTurbo.NET: Nissan 300ZX forum - setting throttle stops on z1 58mm cnc TB's
Subject setting throttle stops on z1 58mm cnc TB's
Posted by WazTTed on August 20, 2011 at 6:35 AM
  This message has been viewed 191 times.
Message ive been having a surging idle issue with my idle recently since my install of the z1 58mm throttles.
what is the proper method of setting the throttle stops correctly. if they close all the way shut they stick shut ..
i know the service manual recommends using a dial gauge but i dont have one and feel that is over kill
should i put a spark plug 0.02mm feeler gauge under the butterfly plate and close the throttle and set that way??
has anyone else had idle issues with the z1 throttles?
this is definately throttle related, i have no boost leaks, fuel pressure is spot on , tps is good, cts is good everything checks out
