TwinTurbo.NET: Nissan 300ZX forum - That is correct but it alone willl not tell the full detail
Subject That is correct but it alone willl not tell the full detail
Posted by ZUL8TR on August 18, 2011 at 4:26 PM
  This message has been viewed 143 times.
In Reply To Re: Oxygen sensor voltage question... posted by Stadsport (PHX) on August 16, 2011 at 02:55 PM
Message of a good O2. An additional more conclusive test is to read the voltage swings because you can get 5 blinks/10sec and still have poor voltage readings. On voltage look for about 0.9v on the high and about 0.1v on the low with 5 blinks/10sec at 2000 rpm warmed up.
Also check the ohms on the heater wire side of the O2. Disconnect the O2 connector to do this and probe the connestor side that is wired to the O2 sensor. If not in spec the O2 will not warm up quicker and that will effect readings sent to the ECU till the O2's.
ZUL8TR in Orlando,FL
