TwinTurbo.NET: Nissan 300ZX forum - I strongly suggest.......
Subject I strongly suggest.......
Posted by Greg D. (Specialty-Z) on August 18, 2011 at 12:11 PM
  This message has been viewed 209 times.
In Reply To Thanks Greg! posted by Madhatter10-6 on August 18, 2011 at 11:04 AM
Message doing one of two things...
1. Install a wide band right away
2. Get on a dyno right away
Because you bought injectors that are new to this platform, it is not likely anyone has a reasonable generic tune that could be used without checking the air-fuel ratios.
If anyone is sending out a "generic tune" for your injectors it is most likely a mathematical guess, or from tuning a extremely small sample at best.
In order to make a reasonable "generic tune" the tuner should have a LARGE sample of extremely similar set ups with the exact injector used to provide anything you should trust.
:are their any "generic tunes" that will work for the injectors that I have?
:I would like to have something to use until I get time to take it to a dyno
