| Subject |
Use caution. IMO every intake runner is different. |
| Posted by |
ZTicket(Dallas) on August 18, 2011 at 7:08 AM |
This message has been viewed 142 times. |
| In Reply To |
#5 Injector with Dremel method posted by ZXRider on August 17, 2011 at 08:57 PM |
| Message |
A few years ago, when my plenum was removed, anticipating dead injectors in the future, I did all 6 and on the last runner I did, (#2) I ground through. I took it to my welding class and was able to fix it (no easy task on cast aluminum). I don't know which runner the above pic is from, but from my experience, he dodged a bullet. Recently I had to grind on it again to clearance new 740cc injectors for the 300 degree fuel rail and I wasn't so confident that there was "plenty of material available" as others have said. I didn't have a bad result as before but I was on pins and needles and was relieved when I finally had removed enough to clear the injector. As far as replacing dead injectors, if I had to do it again, I would choose plenum pull over Dremel method.
| Follow Ups |
Post a Followup |
