TwinTurbo.NET: Nissan 300ZX forum - Re: Is there a seperate sensor for the transmission speed
Subject Re: Is there a seperate sensor for the transmission speed
Posted by sandmanz32 on August 17, 2011 at 3:09 PM
  This message has been viewed 277 times.
In Reply To Is there a seperate sensor for the transmission speed posted by ELDIABLO on August 17, 2011 at 12:11 PM
Message Your speedo wouldnt show a bad reading if the sensor was doi g its job. The speed sensor is connected directly to the cluster, the cluster sends the vss signal to the tcu. The 1st thing id check firs would be the yellow/green wire between pin17 of the cluster and pin 27 of the tcu, that the main signal wire. Theres only 1 speed sensor in the tail of the trans, but theres a engine rev sensor on the top left of the trans that could vauae it to go in fail safe.
......And just as they're about to catch me.....Twin......Turbos......Kick.......In!
