TwinTurbo.NET: Nissan 300ZX forum - Infinite would be an open.. or broken wire.
Subject Infinite would be an open.. or broken wire.
Posted by Draker (Eugene, OR) on August 17, 2011 at 1:09 PM
  This message has been viewed 92 times.
In Reply To Did you replace the det sensor harness. posted by Sleeper_TTZ(SeKy) on August 16, 2011 at 10:33 PM
Message I would check the knock sensor harness itself. Test the wires from one end to the other. Should be low to zero resistance. Then test between both pins on one side, that should be infinite or open. That would indicate there are no wires touching inside the harness.
Do the same for the EFI harness to the ECU and the results should be the same. If they are then that would indicate possible ECU issues. If they are different, then that would say your EFI harness probably has issues.
