TwinTurbo.NET: Nissan 300ZX forum - Converting NA bottom end into TT
Subject Converting NA bottom end into TT
Posted by BlackholeZ on August 17, 2011 at 1:02 PM
  This message has been viewed 138 times.
Message So it's simple right? Just swap pistons right? I doubt it. I'm trying to collect all the details.
Oil squirters are different. TT guys like the NA ones with aftermarket pistons. Do they work with stockers?
I remember something about a check valve or ball valve in the block for oil?
Does the TT oil tree bolt up?
I believe the TT oil pump is higher output. True?
I know a lot is available by searching but the data is so scattered it is almost impossible to track down. Once I get everything collected I will have it put into the Z32 Wiki so it is all in one place.
-Dan
"Capitalization is the difference between helping your Uncle
Jack off a horse, and
helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need
to give her to woody again."
- Dvlhntr
"full alphabetic boost mode"
ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." -
turtleboy on rotary engines
