TwinTurbo.NET: Nissan 300ZX forum - Did you replace the det sensor harness.
Subject Did you replace the det sensor harness.
Posted by Sleeper_TTZ(SeKy) on August 16, 2011 at 10:33 PM
  This message has been viewed 110 times.
In Reply To Help! 91 TT Safety Boost Wont Turn Off. posted by AsaHerring on August 16, 2011 at 09:21 PM
Message I now you say connection but Just asking... If so and still getting the code then I would say there is a problem in the main engine harness, or the ECU... Search the ECU plug pin diagram and locate the pins... Unplug the harness from the det sensor and the ecu and check continuity between the pin and the plug with a multi meter... Two checks on two wires, see if there is continuity and then check and see what the resistance is on each wire... I don't know for sure but I would say that it should be infinite resistance considering its a straight wire..
Any one else correct me if i'm wrong.
