TwinTurbo.NET: Nissan 300ZX forum - Re: Three things...
Subject Re: Three things...
Posted by TRdave on August 13, 2011 at 5:28 PM
  This message has been viewed 90 times.
In Reply To Three things... posted by Stadsport (PHX) on August 13, 2011 at 03:10 PM
Message I just removed the plunum to make sure the gasket is good. It looks good, it is supposed to be sealed with any type of gasket seal or anything? I didn't use any last time becuase from what I remember the rubber on the bottom of the gasket should create the seal. Another thing. 2 of my injectors that I replaced have a pink tip on them. would that make a difference becuase they don't match the other 4? I'm thinking these might not have the right spray pattern or something.
:1. Pull off your CAS and check out the drive pin (on the CAS side and the cam side).
:2. Injector spec is between 10 and 14 ohms. Your car will still run, but any injectors over 14ohms will make the car run like crap.
:3. Did you perform a boost leak test (NAs can, too).
:Good luck with it, sounds like you've already ruled out a lot...
