TwinTurbo.NET: Nissan 300ZX forum - Re: Three things...
Subject Re: Three things...
Posted by TRdave on August 13, 2011 at 4:25 PM
  This message has been viewed 90 times.
In Reply To Three things... posted by Stadsport (PHX) on August 13, 2011 at 03:10 PM
Message CAS pin is there, i would get a cas error if it was out of allignment right?
Rechecked all injectors. 1 reads 11.5, the rest are all between 12.4 and 12.6. Also tested at ECU side of harness and results were the same.
I'm not sure how to perform a boost leak test, but would that cause my car not to start?
:1. Pull off your CAS and check out the drive pin (on the CAS side and the cam side).
:2. Injector spec is between 10 and 14 ohms. Your car will still run, but any injectors over 14ohms will make the car run like crap.
:3. Did you perform a boost leak test (NAs can, too).
:Good luck with it, sounds like you've already ruled out a lot...
