TwinTurbo.NET: Nissan 300ZX forum - Three things...
Subject Three things...
Posted by Stadsport (PHX) on August 13, 2011 at 3:10 PM
  This message has been viewed 92 times.
In Reply To Re: Is the engine turning over with no start or is that posted by TRdave on August 13, 2011 at 02:09 PM
Message 1. Pull off your CAS and check out the drive pin (on the CAS side and the cam side).
2. Injector spec is between 10 and 14 ohms. Your car will still run, but any injectors over 14ohms will make the car run like crap.
3. Did you perform a boost leak test (NAs can, too).
Good luck with it, sounds like you've already ruled out a lot...
