TwinTurbo.NET: Nissan 300ZX forum - Idle Problems...rise / fall (Video)
Subject Idle Problems...rise / fall (Video)
Posted by Madhatter10-6 on August 12, 2011 at 11:43 PM
  This message has been viewed 124 times.
Message Since my Z has been done it hasn't idled right.
Here are the steps that I have take so far:
1) Boost leak test = check
2) Diagnostic codes = 55 no errors
3) New plugs
4) New FPR (and PSI is perfect and rises with boost in 1:1)
5) New Idle Air and checked OHM on Air Reg and took apart. All items are are within spec and looked great.
6) I checked ground on MAF
7) New Gasoline
Profile is up to date.
Here is a video of what it is doing. The odd thing is that the car runs great when I drive it just has the idle that climbs and falls.
Example starts at around 24 seconds in.
[ http://www.youtube.com/watch?v=96xGc5M963c ]
I am not touching the gas the entire time in this video.....this is what it is doing on its own.
The pillar gauges from top to bottom:
Fuel Pressure
Boost / Vacum
Oil Temp
It also sounds like it has a slight miss to it at lower RPMs.
I am out of ideas on this one....any help is greatly appreciated
Madhatter10-6
