TwinTurbo.NET: Nissan 300ZX forum - Re: Hesitation @ high boost
Subject Re: Hesitation @ high boost
Posted by sandmanz32 on August 12, 2011 at 5:55 PM
  This message has been viewed 125 times.
In Reply To Hesitation @ high boost posted by TTZ'sofSWMO on August 12, 2011 at 09:35 AM
Message Lean is bad bad bad! 18 psi on stock turbos is insane! the lean mix is in the tuning, or could be detonation due to timing advance? My advise would be to save up for at least some JWT sport 500's, get nistune, and find a good shop that knows z's well to tune it properly. Also, if you want over 18 psi on pump fuel, meth injection wouldnt be a bad investment in your engine's future. That would allow you to run a more aggressive timing curve. The socketed ecu's are good to a point, but usually the are overly conservative, and if you're doing crazy stuff like running 18psi on stockers, you'll find their limits quick lol
......And just as they're about to catch me.....Twin......Turbos......Kick.......In!
