TwinTurbo.NET: Nissan 300ZX forum - It does burn white...
Subject It does burn white...
Posted by ZTurboFan on August 10, 2011 at 8:28 PM
  This message has been viewed 91 times.
In Reply To Re: Please confirm my Thoughts… Engine & Auto Transmission Issue posted by txq45 on August 08, 2011 at 03:06 PM
Message I know you've pretty much already confirmed this, but the tranny fluid in my auto burns white. And it stinks like hell. And I suggest you remove the exhaust and fully remove all the fluid residue before it gets caked on. I had a leak that was very annoying and in the time frame that I was testing to locate and fix the leak, the fluid baked right on and was quite a bitch to get it off.
The lines going to and from the tranny cooler can be a problem if they aren't hooked up properly. Now, my Z is not a Nissan transmission, but I can tell you on my TH400, if you don't have a crush washer at the lines going to the tranny, it'll leak.
I even bent a washer (by slightly overtightening) and that alone gave me a leak too.
