TwinTurbo.NET: Nissan 300ZX forum - Injector causing cylinder misfire at idle?
Subject Injector causing cylinder misfire at idle?
Posted by BlackholeZ on August 09, 2011 at 7:46 PM
  This message has been viewed 386 times.
Message I've been chasing a misfire on cyl 6. Happens only at idle, the plud appears to be burning a little cooler than the others, but the plug is clean. No sign of excessive oil on the plug. I did compression and leak down and 6 is in line with the rest. Injector ohms out fine, connection with the harness is good, I'm starting to wonder if it just isn't firing right at low loads.
Any thoughts?
-Dan
"Capitalization is the difference between helping your Uncle
Jack off a horse, and
helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need
to give her to woody again."
- Dvlhntr
"full alphabetic boost mode"
ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." -
turtleboy on rotary engines
