TwinTurbo.NET: Nissan 300ZX forum - I am well aware of the valve.
Subject I am well aware of the valve.
Posted by Draker (Eugene, OR) on August 09, 2011 at 10:31 AM
  This message has been viewed 190 times.
In Reply To I told you on 300ZX.com posted by aztecz34 on August 08, 2011 at 08:50 PM
Message If that valve is clogged, you won't have cold air, or it will be slightly cold at best. This was not my issue, and presumably not my problem. As DE944 stated above:
"Mine had a similar issue, i had checked everything and my high side kept developing excessive pressure. The high side pressure would get so high that it would pop the relief valve on the compressor and shoot freon all over. I changed the expansion valve and gutted the tsv and still had the problem. It ended up being a dirty condenser."
I appreciate the input though.
