TwinTurbo.NET: Nissan 300ZX forum - Three things that come to mind to me...
Subject Three things that come to mind to me...
Posted by Stadsport (PHX) on August 08, 2011 at 6:33 PM
  This message has been viewed 224 times.
In Reply To High A/C Pressures on high side? posted by Draker (Eugene, OR) on August 06, 2011 at 07:57 PM
Message 1. Not enough airflow, though it sounds like your fan is working properly and I'm assuming you've cleaned out the condenser and radiator fins~
2. Suction throttle valve sticking. R12 Zs with auto climate control had a STV that liked to go bad, but from what I've heard, when this happens you won't get cold air out of the evaporator. Anything's possible, I suppose.
3. I noticed you said you installed a receiver/drier from a 95... thing is, you should never install a used receiver/drier as they -hate- moisture and other contaminates. I don't fully understand what happens to it, but the FSM makes it pretty clear that if the system is ever exposed to the atmosphere (even through leakage), the receiver/drier should be replaced with a brand new unit. The new ones even come with air-tight caps to keep it sealed until the moment it's installed.
