TwinTurbo.NET: Nissan 300ZX forum - Re: AUTO Tranny Help
Subject Re: AUTO Tranny Help
Posted by txq45 on August 08, 2011 at 3:14 PM
  This message has been viewed 84 times.
In Reply To AUTO Tranny Help posted by aztecz34 on August 07, 2011 at 07:58 PM
Message Sounds like not enough pressure on the clutch pack..
Which could be one of the solenoids..
Not a hard part to change just a little messy.
Drain pan,, (most likely need to anyway)
Remove valve body to get to the solenoids.. remove screws that hold them in and replace.. reverse procedure for installation..
If your fluid is not pink or a shade of red you also need to replace all of it too.. This will give your transmission a extended life..
Most Jiffy lube shops have the machine...
Also, the factory oil cooler is a joke... replace it with just about any aftermarket one, which would increase the cooling on your trans fluid..
Nistune Dealer
ECU socketing ECU eprom upgrades
WWW.AAA-HiperformanceAuto.com
