TwinTurbo.NET: Nissan 300ZX forum - Well there are 2 of them, one on each side.
Draker (Eugene, OR)
on August 08, 2011 at 2:18 PM
Roger, Just checked again...
posted by Zski
on August 08, 2011 at 02:00 PM
They connect to the hardlines that run to the trans cooler. On each side of the bolt is a crush washer, if one is missing or not tightened correctly you will leak. If you are missing a crush washer you will leak a lot.
Please confirm my Thoughts… Engine & Auto Transmission Issue
Zski
13:35:30 08/08/11
I would think you are correct on the smoke.
Draker (Eugene, OR)
13:48:15 08/08/11
Make sure you've got the banjo bolts tight.
Draker (Eugene, OR)
13:54:25 08/08/11
Zski
14:00:40 08/08/11
Well there are 2 of them, one on each side. -
Draker (Eugene, OR)
14:18:56 08/08/11
Thanks will recheck them... (n/m)
Zski
14:19:45 08/08/11
Re: Please confirm my Thoughts… Engine & Auto Transmission Issue
txq45
15:06:11 08/08/11
It does burn white...
ZTurboFan
20:28:47 08/10/11
