TwinTurbo.NET: Nissan 300ZX forum - Only issue I found on the dyno was
Subject Only issue I found on the dyno was
Posted by Sleeper_TTZ(SeKy) on August 07, 2011 at 8:33 PM
  This message has been viewed 111 times.
In Reply To How bad is it to run a Non turbo fuel pump controler posted by Sly on August 07, 2011 at 05:24 PM
Message at about 3k rpm your AF goes rich because it kicks the pump up to full power.. The NA has two stages... The TT has three.
Na kicks the fuel pump all the way up instead of the TT FPC having a middle setting to better meter AF.... Tested via Dyno pulls on both with the FPC being the only difference. No difference in peak power. TT fpc had a little more power from 2500-3500rpm... Nothing real big though.
