TwinTurbo.NET: Nissan 300ZX forum - The Aux fan works when I trigger it with Conzult.
Subject The Aux fan works when I trigger it with Conzult.
Posted by Draker (Eugene, OR) on August 07, 2011 at 12:19 PM
  This message has been viewed 221 times.
In Reply To Z's that were originally equipped with R12 only had posted by aliaZ on August 07, 2011 at 11:34 AM
Message It's in the mid-70's there so it's going to be tough to get the temp to rise, but I'll try blocking off the radiator as noted in the FAQ.
I have a drier from a 95+ Z as well which I believe should have the high cutoff. I'll look into it.
There is a chance the new compressor had more oil in it. I suppose I could drain all the oil using the AC machine and or removing the drain plug on the compressor and refilling. I would think if the compressor was too full wouldn't I see some green oil floating through the site glass?
I'll take a look at all of these things today and give and update. Thanks.
