TwinTurbo.NET: Nissan 300ZX forum - Z's that were originally equipped with R12 only had
Subject Z's that were originally equipped with R12 only had
Posted by aliaZ on August 07, 2011 at 11:34 AM
  This message has been viewed 220 times.
In Reply To High A/C Pressures on high side? posted by Draker (Eugene, OR) on August 06, 2011 at 07:57 PM
Message low pressure cutoff switches. R134 Z's have low/high pressure switches. A drop in retrofit low/high switch is available...I've posted the part number before...available at ackits.com
Maybe the compressor you swapped over had more oil in it than the one that you removed?
Is your fan working properly?
