TwinTurbo.NET: Nissan 300ZX forum - Code 55 and won't start continued
Subject Code 55 and won't start continued
Posted by TRdave on August 06, 2011 at 10:02 AM
  This message has been viewed 90 times.
Message Sorry, I wasn't able to continue my last thread, it is now locked. Here is what I have so far.
91 N/A was running rough and it stalled out on me, now it will not start. I recently replaced the CAS and it was not adjusted correctly which probably caused the car to run rough. I pulled the plugs to check for spark and the tips were black. I replaced the plugs and I do have spark when I spin the CAS.
I have 42 psi fuel pressure after the fuel pressure
All injectors ohm between 13 and 16 ohms.
I checked the ECU for errors and I get a code 55. What else is there to check for?
Thanks!
