TwinTurbo.NET: Nissan 300ZX forum - Re: AC making loud noise when turned on.
Subject Re: AC making loud noise when turned on.
Posted by gbhrps on July 26, 2011 at 7:22 PM
  This message has been viewed 105 times.
In Reply To AC making loud noise when turned on. posted by gbhrps on July 26, 2011 at 07:20 PM
Message :Pull the lower panel below the glove box to get at the HVAC unit. The fan assembly simply unbolts or unscrews from the bottom (three I believe, been a while since I did mine). The fan and motor simply pull down and out of the car after unclipping the wiring connector to the motor.
:You have some debris that got into the fan and is clipping the edge of the blades as it spins. In my case, a mouse had built a very large nest in the middle of the fan over the winter.
As for the AC not working and the mechanic's screw up ... check your fuses to see if any of them didn't care for the current reversal.
Good Luck!
