TwinTurbo.NET: Nissan 300ZX forum - AC making loud noise when turned on.
Subject AC making loud noise when turned on.
Posted by gbhrps on July 26, 2011 at 7:20 PM
  This message has been viewed 135 times.
In Reply To 95 300zx N/A - AC making loud noise when turned on. posted by JayT (Tampa,FL) on July 26, 2011 at 11:19 AM
Message Pull the lower panel below the glove box to get at the HVAC unit. The fan assembly simply unbolts or unscrews from the bottom (three I believe, been a while since I did mine). The fan and motor simply pull down and out of the car after unclipping the wiring connector to the motor.
You have some debris that got into the fan and is clipping the edge of the blades as it spins. In my case, a mouse had built a very large nest in the middle of the fan over the winter. Good Luck!
