TwinTurbo.NET: Nissan 300ZX forum - Which of the two should the car be set to? (n/m)
JMartz
on July 26, 2011 at 7:39 AM
You cant do that.
posted by Woody75 (Denver)
on July 25, 2011 at 10:27 PM
CAS is fully Clockwise after 60k?
Draker (Eugene, OR)
20:24:26 07/25/11
No changes after recount.
Draker (Eugene, OR)
21:01:56 07/25/11
Re: No changes after recount.
jaidieray
21:50:16 07/25/11
2nd (n/m)
CGDriven
21:55:47 07/25/11
Try timing from coil pack 1
sak01
21:54:04 07/25/11
I have gone thru 3 different timing lights trying to get
10:18:13 07/28/11
90GoldZ
21:56:22 07/25/11
& time from coilpack 1.
90GoldZ
21:58:26 07/25/11
Datascan reads 15 degrees.
Draker (Eugene, OR)
22:24:02 07/25/11
You cant do that.
Woody75 (Denver)
22:27:48 07/25/11
90GoldZ
22:33:22 07/25/11
Oh man.. You are totally right! (n/m)
Draker (Eugene, OR)
22:57:07 07/25/11
This is the info I've been missing!
Draker (Eugene, OR)
22:54:16 07/25/11
Which of the two should the car be set to? (n/m) -
JMartz
07:39:35 07/26/11
You can only physcially set the CAS.
Woody75 (Denver)
08:39:04 07/26/11
Do you put both wires of the loop in the pick up
JMartz
09:47:32 07/26/11
There is only 1 wire. (n/m)
Woody75 (Denver)
10:30:28 07/26/11
With the car fully warmed up...
sak01
08:40:48 07/26/11
I set the timing with the loop to the mark
JMartz
07:36:43 07/26/11
read what Woody posted above, can't do it that way. (n/m)
BoneZ (MD)
06:22:39 07/28/11
Besides all of the other good points mentioned all ready
Wright (Ca)
16:21:16 07/26/11
Already compared pulleys.
Draker (Eugene, OR)
18:08:36 07/26/11
Even on the first coil I get multiple readings. You just
treese88
22:17:42 07/27/11
