TwinTurbo.NET: Nissan 300ZX forum - its from the engine warm up cycle
Subject its from the engine warm up cycle
Posted by DE944 on July 25, 2011 at 10:59 PM
  This message has been viewed 107 times.
In Reply To Proper gas/air mixture indicators posted by Pittsman on July 25, 2011 at 03:39 PM
Message The engine warm up cycle on AIV equipped cars runs rich until the temp sensor tells the ECU that it is warm, AND the o2 sensors are warm enough to send a stable signal. After warm up, the ECU will run a slightly richer mixture to keep the cats hot. There is no adjustment for this. Make sure that when warm the A/F ratio is correct, o2 are functioning correctly, and all "tune" related items are correct. Hope this helps.
