TwinTurbo.NET: Nissan 300ZX forum - Datascan reads 15 degrees.
Draker (Eugene, OR)
on July 25, 2011 at 10:24 PM
& time from coilpack 1.
posted by 90GoldZ
on July 25, 2011 at 09:58 PM
I am aware of the ptu loop being unreliable. But figured since the software said it was 15 degrees btdc, then it was on the money.
CAS is fully Clockwise after 60k?
Draker (Eugene, OR)
20:24:26 07/25/11
No changes after recount.
Draker (Eugene, OR)
21:01:56 07/25/11
Re: No changes after recount.
jaidieray
21:50:16 07/25/11
2nd (n/m)
CGDriven
21:55:47 07/25/11
Try timing from coil pack 1
sak01
21:54:04 07/25/11
I have gone thru 3 different timing lights trying to get
10:18:13 07/28/11
90GoldZ
21:56:22 07/25/11
90GoldZ
21:58:26 07/25/11
Datascan reads 15 degrees. -
Draker (Eugene, OR)
22:24:02 07/25/11
You cant do that.
Woody75 (Denver)
22:27:48 07/25/11
90GoldZ
22:33:22 07/25/11
Oh man.. You are totally right! (n/m)
Draker (Eugene, OR)
22:57:07 07/25/11
This is the info I've been missing!
Draker (Eugene, OR)
22:54:16 07/25/11
Which of the two should the car be set to? (n/m)
JMartz
07:39:35 07/26/11
You can only physcially set the CAS.
Woody75 (Denver)
08:39:04 07/26/11
Do you put both wires of the loop in the pick up
JMartz
09:47:32 07/26/11
There is only 1 wire. (n/m)
Woody75 (Denver)
10:30:28 07/26/11
With the car fully warmed up...
sak01
08:40:48 07/26/11
I set the timing with the loop to the mark
JMartz
07:36:43 07/26/11
read what Woody posted above, can't do it that way. (n/m)
BoneZ (MD)
06:22:39 07/28/11
Besides all of the other good points mentioned all ready
Wright (Ca)
16:21:16 07/26/11
Already compared pulleys.
Draker (Eugene, OR)
18:08:36 07/26/11
Even on the first coil I get multiple readings. You just
treese88
22:17:42 07/27/11
