TwinTurbo.NET: Nissan 300ZX forum - Re: shift solenoid B replacement help
Subject Re: shift solenoid B replacement help
Posted by sandmanz32 on July 25, 2011 at 9:04 PM
  This message has been viewed 287 times.
In Reply To shift solenoid B replacement help posted by Booster (MD) on July 23, 2011 at 11:32 AM
Message Not second guessing you, but you said you had a TPS code as well, Have you made sure the TPS wasn't the culprit? If the TPS is sending a bad signal to the TCU the tans will not shift properly, and may set other dtc's as a result.
Hondas are like Tampons; every pussy has one!
