TwinTurbo.NET: Nissan 300ZX forum - To remove the heads you will have to remove the
Subject To remove the heads you will have to remove the
Posted by JMartz on July 25, 2011 at 1:57 PM
  This message has been viewed 110 times.
In Reply To Re: Do a leak down first. posted by Zcrazy521 on July 25, 2011 at 01:39 PM
Message cam drive belt before hand. Go ahead and do the leak down as suggested, although if you have valves stuck open, I don't know what the test would indicate. In any case, by removing the water hoses, radiator, fan, fan clutch, CAS, igniter chip, their wiring and the aluminum water hard pipes, you will gain access to the belt covers and subsequently the belt and pulleys. You can then check for proper cam timing.
You only need to remove the heads for valve/seat work if the valves are bent from making contact with the pistons. Once timing is corrected, do another comp check. If good, your valves are ok, if bad, remove the heads.
